[gdal-dev] building with PDF driver on Windows
Even Rouault even.rouault at mines-paris.org
Thu Oct 14 13:32:53 EDT 2010
Le jeudi 14 octobre 2010 17:01:06, Joaquim Luis a écrit :
> Hi,
> I tried to build GDAL on Win with PDF support and CV2010
> Well that's an adventure.
I trust you and didn't even try this way.
Instead I just downloaded the kde-win32 installer, used the "packager mode"
(or whatever it is called. I'm just quoting from my memory of doing this a few
weeks ago), and selected the poppler, freetype and lcms packages and their
developement packages. The only requirement for GDAL is poppler, freetype and
lcms appears to be poppler requirements on this KDE build. But those lib only
work with MSVC 2008 if I remember.
