[gdal-dev] mod_python issue with libtiff
Even Rouault even.rouault at mines-paris.org
Fri Oct 15 14:32:00 EDT 2010
Andreas,
I'm somehow happy to see that you've hit the warning. It means that it was
usefull to add it and probably saved you headaches when things would have
started to crash awfully...
Now, I'm afraid I cannot really help you more. There's something in your
Apache that loads a libtiff 3.X... Don't you load other modules that could load
libtiff indirectly ? A "ld foo.so | grep libtiff" on the potential .so python
modules might help find the culprit.
Or perhaps if you move/rename /usr/lib/libtiff.so* to something else, the
culprit will complain and you'll be able to identify it.
Le vendredi 15 octobre 2010 17:26:13, Andreas Neumann a écrit :
> Hi,
> I recently upgraded my gdal version to the recent SVN version. The
> command-line tools work fine, but my python scripts inside Apache
> mod_python fail with the following error:
> ERROR 1: WARNING ! libtiff version mismatch : You're linking against
> libtiff 3.X but GDAL has been compiled against libtiff >= 4.0.0
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] mod_python
> (pid=2117, interpreter='srv139.stadt-uster.ch', phase='PythonHandler',
> handler='mod_python.publisher'): Application error
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] ServerName:
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] DocumentRoot:
> '/home/www/www/'
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] URI:
> '/geodatenshop/extract_meta.py/raster'
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Location: None
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Directory: '/'
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Filename:
> '/home/www/www/geodatenshop/extract_meta.py'
> [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] PathInfo:
> '/raster' [Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198]
> Traceback (most recent call last):
> "/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1537, in
> HandlerDispatch\n    default=default_handler, arg=req,
> silent=hlist.silent)
> "/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1229, in
> _process_target\n    result = _execute_target(config, req, object, arg)
> "/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1128, in
> _execute_target\n    result = object(arg)
> "/usr/lib/python2.6/dist-packages/mod_python/publisher.py", line 213, in
> handler\n    published = publish_object(req, object)
> "/usr/lib/python2.6/dist-packages/mod_python/publisher.py", line 425, in
> publish_object\n    return publish_object(req,util.apply_fs_data(object,
> req.form, req=req))
> "/usr/lib/python2.6/dist-packages/mod_python/util.py", line 554, in
> apply_fs_data\n    return object(**args)
> "/home/www/www/geodatenshop/extract_meta.py", line 18, in raster\n
> req.write('\\t<driver>'+dataset.GetDriver().ShortName+'/'+dataset.GetDriver
> ().LongName+'</driver>\\n') [Fri Oct 15 17:03:22 2010] [error] [client
> 10.63.238.198] AttributeError: 'NoneType' object has no attribute
> 'GetDriver'
> I set the libtiff to "internal" in the configure options before the
> compile.
> I don't understand why the mod_python scripts link to libtiff 3.x. Why are
> the commandline tools (gdal-info, gdal-translate, gdal_merge.py, etc.)
> working fine, but the scripts inside mod_python do not.
> Both are using python2.6.
> Thank you very much for any pointers or hints on what may be wrong in my
> configuration.
> Andreas
