[gdal-dev] mod_python issue with libtiff
Christopher Barker Chris.Barker at noaa.gov
Fri Oct 15 14:59:16 EDT 2010
On 10/15/10 11:32 AM, Even Rouault wrote:
> There's something in your
> Apache that loads a libtiff 3.X... Don't you load other modules that could load
> libtiff indirectly ? A "ld foo.so | grep libtiff" on the potential .so python
> modules might help find the culprit.
But if you need the "culprit", what then?
>> I set the libtiff to "internal" in the configure options before the
>> compile.
Perhaps you could re-build GDAL with the system libtiff instead, if all
your Apache modules use the same one, I'd think you'd be all set. That's
kind of the Linux way, anyway.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
