[gdal-dev] building with PDF driver on Windows + ?
Brent Fraser bfraser at geoanalytic.com
Sun Oct 17 14:24:53 EDT 2010
Joaquim,
   Many thanks for the info.  I may go the kde-win32 route for now to
skip the building of poppler.lib, but I expect that eventually I may
need to build it from source, especially for mapserver.
Thanks again,
Brent Fraser
On 10/17/2010 12:11 PM, Joaquim Luis wrote:
> Brent,
> From memory, as I don't find the CMake cash with exact details. I
> first built freetype, which I think is mandatory, and than because I
> already had them built but don't know if they are a must-be, I added
> also zlib, jpeg to the CMake list.
> My first error was to not select 'splash' because I didn't know what
> it was but it's part of poppler and needs to be selected. I did not
> include any Qt stuff and probably some other.
> Once it is built (I used only VC2010) there is the mess of the
> includes. You will need to include the root directory where the whole
> poppler tree lives, plus that ../poppler  plus still one other dir
> that holds only one .h file. I moved that .h to one of the other
> places and now use this (my names) in nmake.opt
> POPPLER_CFLAGS = -IC:/programs/compa_libs
> -IC:/programs/compa_libs/poppler
> Good luck
> Joaquim
>>  I'm about to embark on compiling Poppler on Windows to get
>> Geospatial PDF support in GDAL.  Any recommendations with respect to
>> compiler version, dependencies, CMake options, etc?
>> Thanks!
>> Brent Fraser
>> On 10/14/2010 3:23 PM, Joaquim Luis wrote:
>>> Did I mention before that the propeller (sorry, poppler) doesn't
>>> have any building instructions for Windows?
>>> Well, the CMakeLists.txt is incomplete and does not add the contents
>>> of the "splash" directory to the project. After adding all *.cc from
>>> 'splash' to project, GDAL is happy with the poppler.lib and now
>>> gdalinfo says
>>>   KMLSUPEROVERLAY (rw): Kml Super Overlay
>>>   XYZ (rwv): ASCII Gridded XYZ
>>>   HF2 (rwv): HF2/HFZ heightfield raster
>>>   PDF (rov): Geospatial PDF
>>> but I'm now confused with the presence of the KMLSUPEROVERLAY
>>> because my nmake.opt has
>>> # Uncomment out the following to enable KML Super-Overlay support.
>>> #KMLSUPEROVERLAY_SUPPORTED = YES
>>> #MINIZIP_INCLUDE = -I$(OSSIM_HOME)\minizip\src
>>> #MINIZIP_LIBRARY = $(OSSIM_HOME)\minizip\release\minizip.lib
>>> Not complaining. Just reporting.
>>> Joaquim
>>>> On 14-10-2010 18:32, Even Rouault wrote:
>>>>> Le jeudi 14 octobre 2010 17:01:06, Joaquim Luis a écrit :
>>>>>> Hi,
>>>>>> I tried to build GDAL on Win with PDF support and CV2010
>>>>>> Well that's an adventure.
>>>>> I trust you and didn't even try this way.
>>>>> Instead I just downloaded the kde-win32 installer, used the
>>>>> "packager mode"
>>>>> (or whatever it is called. I'm just quoting from my memory of
>>>>> doing this a few
>>>>> weeks ago), and selected the poppler, freetype and lcms packages
>>>>> and their
>>>>> developement packages. The only requirement for GDAL is poppler,
>>>>> freetype and
>>>>> lcms appears to be poppler requirements on this KDE build. But
>>>>> those lib only
>>>>> work with MSVC 2008 if I remember.
>>>> Even,
>>>> Hmm, on a further check those symbols are from poppler so it's not
>>>> a lcms fault.
>>>> I get another error building poppler referring iconv.h that I
>>>> ignore either but selected as a no dependency in CMake, but this
>>>> affect the creation of a poppler-cpp.lib, not poppler.lib so I'm
>>>> not sure it relates to the GDAL error.
>>>> I would like to build these dependencies myself because:
>>>> 1. I don't want to use anything that dares to create manifests
>>>> dependencies
>>>> 2. I want to be able to build 64 bits versions too.
>>>> Anyway, I found these warnings too that are unrelated to this PDF
>>>> driver issue
>>>> json_util.c
>>>> json_util.c(62) : warning C4013: 'open' undefined; assuming extern
>>>> returning int
>>>> json_util.c(71) : warning C4013: 'read' undefined; assuming extern
>>>> returning int
>>>> json_util.c(74) : warning C4013: 'close' undefined; assuming extern
>>>> returning int
>>>> json_util.c(109) : warning C4013: 'write' undefined; assuming
>>>> extern returning int
>>>> ogrsf_frmts.lib(resolvexlinks.obj) : warning LNK4221: This object
>>>> file does not define any previously undefined public symbols, so it
>>>> will not be used by any link operation that consumes this library
>>>> and many "blabla ... possible loss of data" warnings.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
