[gdal-dev] building with PDF driver on Windows + ?
Tamas Szekeres
szekerest at gmail.com
Sun Oct 17 16:24:35 EDT 2010
Hi poppler gurus,
I've also compiled poppler.lib (version 0.14.4) with various versions of
MSVC, but it seems to generate double free memory corruptions in gdal.
A single run of pdf.py (from the autotest suite) seems to complete
successfully, however running the script multiple times (in a batch) could
eventually generate a crash. Has anyone run into the same issue?
Best regards,
Tamas
2010/10/17 Joaquim Luis <jluis at ualg.pt>
> On 17-10-2010 19:24, Brent Fraser wrote:
>> Joaquim,
>> Many thanks for the info. I may go the kde-win32 route for now to skip
>> the building of poppler.lib, but I expect that eventually I may need to
>> build it from source, especially for mapserver.
> Right, and
>>> From memory, as I don't find the CMake cash with exact details.
> obviously I meant "cache" not "cash"
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101017/c36f3f6b/attachment.html
