[gdal-dev] Reading GML
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Oct 20 06:07:34 EDT 2010
Paul,
1.7 doesn't support some geometry types that 1.8 does. GDAL1.8 is yet to be
released. You have to build it yourselves.
You can find a nightly snapshot of the source code for the trunk (1.8) at
http://trac.osgeo.org/gdal/wiki/DownloadSource#NightlySnapshots
Build hints: http://trac.osgeo.org/gdal/wiki/BuildHints
On Wed, Oct 20, 2010 at 2:45 PM, Paul Meems <bontepaarden at gmail.com> wrote:
> Hi all,
> I have a GML which I want to convert to shapefile.
> I've started with checking the file with ogrinfo (v1.7.2).
> It returns "Unrecognised geometry type <Surface>."
> After searching a bit it seems GDAL v1.8 might read the GML properly.
> So I'm looking for the binaries of GDAL v1.8. At Tamas his site I can
> download the v1.7.2 version but I can't find the v1.8 binaries.
> Does anybody know where I can download that version or do I need to build
> them myself?
> Thanks,
> Paul
> The Netherlands
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101020/253cb081/attachment.html
