[gdal-dev] OCI driver supports DeleteLayer but reports otherwise
Even Rouault even.rouault at mines-paris.org
Thu Oct 21 17:05:02 EDT 2010
Le jeudi 21 octobre 2010 22:50:25, Anders Moe a écrit :
> Hi everyone
> Just did a
>   svn checkout https://svn.osgeo.org/gdal/trunk/gdal gdal
> The OGR/OCI driver seems to have a functional ::DeleteLayer but does not
> report this as a capability. Therefore, it will not respond to
> ogr2ogr   -overwrite
> either. However the SQL command DELLAYER is understood, which in turn calls
> ::DeleteLayer.
Perhaps you should open a ticket to track that.
> I think the sqlite driver has a similar inconsistency.
It wasn't actually implementing the exact expected interface, but it was doing
99% of the job, so I've just implemented the 1% missing.
> Cheers,
> Anders
