[gdal-dev] problems to cut form large image
Jan Tappenbeck tappenbeck at widemann.de
Fri Oct 22 12:14:24 EDT 2010
   hi !
i want to cut a part of a lage (7gb) tiff-image and use this command:
C:\Program Files (x86)\FWTools2.4.7>gdalwarp -r near -te 2608000
55900100 2613104.5424 5582270.5709 -of GTiff -o F:\wt_3a.tif
D:\weissenturm\streifen_3_GK2.tif
but i get following message:
Usage: gdalwarp [--help-general] [--formats]
      [-s_srs srs_def] [-t_srs srs_def] [-to "NAME=VALUE"]
      [-order n] [-tps] [-rpc] [-geoloc] [-et err_threshold]
      [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
      [-wo "NAME=VALUE"] [-ot Byte/Int16/...] [-wt Byte/Int16]
      [-srcnodata "value [value...]"] [-dstnodata "value [value...]"]
-dstalpha
      [-r resampling_method] [-wm memory_in_mb] [-multi] [-q]
      [-cutline datasource] [-cl layer] [-cwhere expression]
      [-csql statement] [-cblend dist_in_pixels]
      [-of format] [-co "NAME=VALUE"]*
      srcfile* dstfile
  Available resampling methods:
      near (default), bilinear, cubic, cubicspline, lanczos.
did anybody now anything about this message ??
regards Jan .-)
