[gdal-dev] GDAL rejecting Winkel Tripel projection
William Kyngesburye woklist at kyngchaos.com
Fri Oct 22 16:50:54 EDT 2010
So, why?  Is it because it has no defined inverse projection?  I think aitoff is another such, and it's not handled by GDAL either.
I see a +wktext option mentioned in ogr_srs_proj4.cpp:importFromProj4(), but it doesn't help.  I guess importFromProj4() looks at the projection and rejects the proj4 string before +wktext is helpful.
If I could figure out a WKT definition, does GDAL restrict that?
Any other way I can get GDAL to use wintri?
On Oct 22, 2010, at 3:07 PM, Even Rouault wrote:
> apparently, the OGRSpatialReference object has currently no support for this
> projection.
> Le vendredi 22 octobre 2010 21:50:59, William Kyngesburye a écrit :
>> Using gdalwarp and ogr2ogr with:
>> -t_srs '+proj=wintri'
>> I get:
>> Translating source or target SRS failed:
>> +proj=wintri
>> and:
>> Failed to process SRS definition: +proj=wintri
>> respectively.
>> Other proj-style SRS definitions work, but not wintri.  It works directly
>> with the proj program.
>> Is GDAL blocking use of wintri, or not configured to use it?
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> All generalizations are dangerous, even this one.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
