[gdal-dev] Coding for appending to a database in OGR
    Even Rouault
    even.rouault at mines-paris.org
    Thu Oct 28 06:09:46 EDT 2010
Hi Peter,
Do you mean that just after issuing a CreateFeature(), the feature ID isn't set
to the correct value (the one that you'll find after dataset reopening) ?
You have to be more specific about which OGR driver you are talking about
because the mechanisms for setting/retrieving FID is driver specific.
Perhaps a small snippet of code would help to understand what you do / would
like to do.
If you're interested in the PG driver, here's a relevant ticket :
http://trac.osgeo.org/gdal/ticket/3744
Best regards,
Even
> Dear Team,
>      I've reviewed the change log for release 8 so far and do not think that
> this question is version specific.
>      I'm coding to support an incremental process for loading a large spatial
> database from a set of distribution objects.  I have noted that my present
> approach results in the OGR_FID column values restarting at 1 for each
> append.
> This is clearly an error!  However, there does not appear to be a method for
> initialising the 'nextfidtowrite' value in the API.  What is the best
> strategy
> to adopt?
>      So far as I can see, there appear to be two options.  One is to read
> every
> feature until there are no more to read: I'd rather not do that.  The other
> would involve opening the layer, reading the featurecount and then requesting
> the featurecount'th feature - featurecount'th + 1 should give an error.  Both
> methods should leave the current feature being the last existing feature, but
> is
> this sufficient to effectively initialise the value at which the next FID
> will
> start?
> Thanks and best wishes,
> Peter
> Peter J Halls, GIS Advisor, University of York
> Telephone: 01904 323806     Fax: 01904 323740
> Snail mail: IT Services, University of York, Heslington, York YO10 5DD
> This message has the status of a private and personal communication
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
