[gdal-dev] [GDALBUILDVRT]Syntax to do tiles
Even Rouault even.rouault at mines-paris.org
Thu Oct 28 11:38:40 EDT 2010
Selon Tacot <cfab13 at hotmail.fr>:
gdalbuildvrt is aimed at building a single dataset from a mosaic of tiles. You
just want to do the contrary. You were on a better track the other day when you
were exploring gdal_retile.
Generally the syntax for GDAL utilities is there :
http://gdal.org/gdal_utilities.html
> Hi
> I would like to reshape a ECW pictures in several tiles.
> Would it be possible to translate ECW in VRT; cut the VRT in tiles, and
> re-translate all VRT in ECW?
> And if it's possible, what are the syntax for those commands?
> Thanks
http://osgeo-org.1803224.n2.nabble.com/GDALBUILDVRT-Syntax-to-do-tiles-tp5682930p5682930.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
