[gdal-dev] RE: Memory leak from GDALRasterIO
BradC bchrist at iinet.net.au
Thu Oct 28 11:55:40 EDT 2010
Hi All,
I am working on fixing a memory use issue in the Virtual Planet Builder
project (an off shoot of OpenSceneGraph) and have come accross the exact
issue described in this thread.
The code essential runs in a loop creating an image pyramid from a large ECW
file. During this loop there a very large number of RasterIO() calls. When
doing this memory use grows continually, seemingly without limit. If I close
and repoen my GDALDataSet regulary then I regain all the memory but it seems
from  this thread there should be a much better way to control memory use.
I have tried calling GDALSetCacheMax() with values from 1 to 1,000,000 with
no effect. I have also tried calling while(GDALFlushCacheBlock()); after
each RasterIO call, once again with no effect.
I am hoping somebody could point me in the right direction because I am
running out of ideas.
Cheers,
Brad
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Memory-leak-from-GDALRasterIO-tp5352901p5683178.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
