[gdal-dev] RE: Worldfile creation inconsistency with gdal_translate
NeilJ neil.jakeman at findmaps.co.uk
Fri Oct 29 07:02:47 EDT 2010
How embarrassing.
Thanks for your keen eyed assistance
  _____
[mailto:ml-node+5685852-1135641362-298918 at n2.nabble.com]
Sent: 29 October 2010 11:14
To: NeilJ
Subject: Re: Worldfile creation inconsistency with gdal_translate
Try spelling the option correctly (both in the argument and in your report):
gdal_translate -of JPEG -co WORLDFILE=YES -a_srs EPSG:27700 HP40SE.tif
HTH
On Fri, Oct 29, 2010 at 8:59 PM, NeilJ <[hidden email]> wrote:
> Please can someone explain to me why I get the message "Waring 6: Driver
> JPEG does not support WORDFILE creation option" when using gdal_translate
on
> a windows command line (FW Tools 2.4.7), when running:
> gdal_translate -of JPEG -co WORDLFILE=YES -a_srs EPSG:27700 HP40SE.tif
> F:\geo_streetview\jpg\HP40SE.jpg
> The tif in question has the following details:
> Driver: GTiff/GeoTIFF
> Files: HP40SE.tif
> Size is 5000, 5000
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS[,
>        DATUM["unknown",
>            SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]],
>    AUTHORITY["EPSG","27700"]]
> Origin = (445000.000000000000000,1205000.000000000000000)
> Pixel Size = (1.000000000000000,-1.000000000000000)
> Metadata:
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  COMPRESSION=DEFLATE
>  INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  445000.000, 1205000.000)
> Lower Left  (  445000.000, 1200000.000)
> Upper Right (  450000.000, 1205000.000)
> Lower Right (  450000.000, 1200000.000)
> Center      (  447500.000, 1202500.000)
> Band 1 Block=5000x1 Type=Byte, ColorInterp=Red Band 2 Block=5000x1
> Type=Byte, ColorInterp=Green Band 3 Block=5000x1 Type=Byte,
ColorInterp=Blue
> I am very confused by the worldfile=yes option as I have used it before on
> other conversions without a problem.
> Any advice on when and why this does/doesn't work?
http://osgeo-org.1803224.n2.nabble.com/Worldfile-creation-inconsistency-with
-gdal-translate-tp5685831p5685831.html
<http://osgeo-org.1803224.n2.nabble.com/Worldfile-creation-inconsistency-wit
h-gdal-translate-tp5685831p5685831.html?by-user=t>
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> [hidden email]
Michael Sumner
Institute for Marine and Antarctic Studies, University of Tasmania
Hobart, Australia
e-mail: [hidden email]
[hidden email]
  _____
View message @
-gdal-translate-tp5685831p5685852.html
To unsubscribe from Worldfile creation inconsistency with gdal_translate,
click
<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscr
ibe_by_code&node=5685831&code=bmVpbC5qYWtlbWFuQGZpbmRtYXBzLmNvLnVrfDU2ODU4Mz
F8LTc3MzM2MTY0MQ==>  here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Worldfile-creation-inconsistency-with-gdal-translate-tp5685831p5686012.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101029/3878ea58/attachment.html
