[gdal-dev] _gdal_array not found
Jorge Arévalo jorge.arevalo at deimos-space.com
Fri Oct 29 07:20:19 EDT 2010
2010/10/29 Even Rouault <even.rouault at mines-paris.org>:
> Jorge,
> WriteArray() needs the gdal-numpy module to be built. So ensure you have numpy
> and numpy-devel packages installed (or whatever they are named on your distro)
> when rebuilding the GDAL python bindings. I guess you lack the numpy-devel
> package that is necessary for building and probably not installed if you've just
> installed the packaged version.
Hi Even,
Thanks for the fast responde. That sounds very logic. I built numpy
from sources too (numpy 1.5.0) so, what should I do if I want the
development packages? I did a
python setup.py build --fcompiler=gnu95
python setup.py install
Isn't it enough?
BTW, I found that
http://download.opensuse.org/repositories/home:/ashigabou/SLE_10/x86_64/.
I think I'll try it with these packages...
>> Hi,
>> I'm using Python 2.7, with GDAL 1.7.2 bindings. Piece of code:
>> dst_ds = raster.Create( tiff, tiff_width, tiff_height, 4, gdal.GDT_Byte)
>> zeros = numpy.zeros( (tiff_height, tiff_width), numpy.uint8 )
>> dst_ds.GetRasterBand(1).WriteArray( zeros )
>> In the "WriteArray" line, I get this exception:
>> File "myFile.py", line 389, in createBlankRasters
>>   File "/usr/local/lib/python2.7/site-packages/osgeo/gdal.py", line
>> 898, in WriteArray
>>     import gdalnumeric
>>   File "/usr/local/lib/python2.7/site-packages/osgeo/gdalnumeric.py",
>> line 1, in <module>
>>     from gdal_array import *
>>   File "/usr/local/lib/python2.7/site-packages/osgeo/gdal_array.py",
>> line 25, in <module>
>>     _gdal_array = swig_import_helper()
>> line 17, in swig_import_helper
>>     import _gdal_array
>> ImportError: No module named _gdal_array
>> Ok, the file _gdal_array.py doesn't exist. But this code works with
>> Python 2.4 and GDAL 1.6.0 in the same machine (Suse Enterprise 10.2
>> x86_64).
>> Comparing the contents of the
>> /usr/local/lib/python2.7/site-packages/osgeo/ directory with the
>> contents of the equivalent directory of the other version of Python
>> (/usr/lib/python2.4/site-packages/GDAL-1.6.0-py2.4-linux-x86_64.egg/osgeo/),
>> I find several files missing in the newer one (2.7). Files like
>> "_gdal_array.py", "_gdal_array.pyc", "_gdalconst.py",
>> "_gdal_array.so", "_gdalconst.so", "_gdal.py", "_gdal.pyc",
>> "_gdal.so", and so on. All the missing files starting with "_"
>> The newer installation (2.7) was created from sources, building python
>> 2.7 and GDAL 1.7.2 (with "configure --with-python && make && make
>> install"). The previous installation (2.4) was created from package
>> manager (Suse YaST).
>> I've looking for the missing files in another directories, but they
>> don't exist. I suppose they weren't compiled, but why? If they're no
>> longer neded with GDAL 1.7.2, why is python 2.7 asking for them? I
>> need the code to work in this new version. Any clues?
>> Many thanks in advance,
>> Jorge Arévalo
>> Internet & Mobilty Division, DEIMOS
>> http://mobility.grupodeimos.com/
>> http://gis4free.wordpress.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Jorge Arévalo
