[gdal-dev] Coding for appending to a database in OGR
Fri Oct 29 09:23:22 EDT 2010
Peter J Halls wrote:
> Frank and team,
>    having reviewed the code again and the comments made by others, for
> which thanks, it seems to me that there is a possible solution that
> might resolve all the concerns.  I've asked my DBA for performance
> expectation comments, but have not yet heard back from him.
>    Instead of trying to track the current FID and where the caller has
> not specified a value  'SELECT max(OGR_FID) + 1 FROM <tablename>' could
> be used instead.  This will always return the maximum value plus one and
> consigns the work to Oracle.  This will be 'safe' for multiple updaters
> and saves the overhead / risk of enquiring the value and updating it in
> the code.
>    However, one side effect of this is that the value is not readily
> known to OGR.  As this is only when writing a new feature to the
> database, does this matter?  Is there any reliance on the FID within a
> newly created / written feature having the destination FID value on
> return - I suspect that, in the majority of instances, the next call is
> to destroy the feature handle?  As this would be a change in behaviour,
> at least it will be if I am correct that only the BoundCreateFeature
> method is actually used, then this may be significant.
> How do others regard this?  Is it a big issue or a non-issue?
Peter,
I am quite concerned about the performance impact of doing the MAX()
operation for every feature insert.   I also would consider it a major
disadvantage to not return the FID properly set on the feature.
Best regards,
