[gdal-dev] Two OGR Driver questions: specifically OCI but really a general question
Fri Oct 29 09:44:42 EDT 2010
Peter J Halls wrote:
> Dear Team,
>    would someone please explain to me the purpose of the
> UnboundCreateFeature method?  Within the OCI driver it does not appear
> that this method can ever get invoked: is it superseded by the
> BoundCreateFeature method?
>    Secondly, the OCI driver BoundCreateFeature method appears to write
> the FID value into the feature data structure as well as write it out
> into the SQL to perform the action; the UnboundCreateFeature method does
> not.  Is this a requirement?
Peter,
I don't really recall the reason for the bound and unbound versions.
But the unbound case can still be used if the MULTI_LOAD=false layer
creation option is used.
Best regards,
