[gdal-dev] Reading MXD files
Benjamin Welton benjamin.r.welton at wmich.edu
Mon Sep 6 00:09:02 EDT 2010
  Hey Ivan,
     Yeah that's what im thinking that id have to access the COM API in
ArcGIS 9 to get this accomplished. I don't actually need to read the
data in the layers that are included in the document only the name of
the layer in the document and the corresponding file/database name for
the layer.  Im going to give the client dispatcher a try and see what i
can hack up to get this done.
     Right now im thinking worst case scenario i have to write something
in java to do the actual reading of the MXD files until we make the
upgrade to ArcGIS 10 (which has the ArcPY module which can read MXD's).
Id like to avoid using java if possible to keep the code all python :-P.
Thanks for your help,
Ben
On 9/3/2010 8:36 PM, Lucena, Ivan wrote:
> Ben,
> There are some interfaces on the ArcObject package that let you not
> exactly *ready* the MXD but you can get some useful information from
> the document. I believe that you can access the ArcObject COM API in
> ArcGIS 10 or 9 by using the win32com.client.Dispatch() the same way as
> you can load the "esriGeoprocessing.GpDispatch.1". You can use the
> tools on PythonWin to browse to all the available ArcGIS components.
> >>> import win32com.client
> >>> arcobj = win32com.client.Dipath("< What should goes here ? >")
> It is only a wild guess, I am not even running Windows now to do a
> quick test, but I hope it would help you.
> Ivan
> Benjamin Welton wrote:
>>  Can you do that with ArcGIS 9.3? i was under the impression from the
>> doc's/forums that it's only available in the arcpy package in 10.
>> Ben
>> On 9/4/2010 5:44 PM, Paolo Corti wrote:
>>>>     Im wondering if there is any way to read MXD files in ether
>>>> gdal or some other python based extension. I'm not looking for the
>>>> raster data for the files only the filename/SDE name of the layer
>>>> and the name of the layer in the MXD file. Is there any easy way to
>>>> pull this information out of the MXD?
>>> I think your only option is to use the ArcGis Python library, but you
>>> need a license for doing so
>>> Paolo
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
