[gdal-dev] Fedara 13 and ECW
Nahum Castro nahumcastro at gmail.com
Tue Sep 7 14:06:27 EDT 2010
I'am trying to compile gdal 1.7.2 on fedora 13 x86_64 with ECW, but i have
the next problem when making.
/bin/sh /home/nahum/Descargas/gdal-1.7.2/libtool --mode=link    g++
gdalmanage.lo  /home/nahum/Descargas/gdal-1.7.2/libgdal.la -o gdalmanage
libtool: link: g++ .libs/gdalmanage.o -o .libs/gdalmanage
/home/nahum/Descargas/gdal-1.7.2/.libs/libgdal.so
/usr/bin/ld: /usr/local/lib/libNCSUtil.so.0: undefined reference to symbol
'pthread_cancel@@GLIBC_2.2.5'
/usr/bin/ld: note: 'pthread_cancel@@GLIBC_2.2.5' is defined in DSO
/lib64/libpthread.so.0 so try adding it to the linker command line
/lib64/libpthread.so.0: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make[1]: *** [gdalmanage] Error 1
make[1]: se sale del directorio `/home/nahum/Descargas/gdal-1.7.2/apps'
make: *** [apps-target] Error 2
here is my configure
./configure --with-pg --with-libtiff=internal --with-geotiff=internal
--with-ecw --with-mysql --with-sqlite3 --with-geos --with-static-proj4
--with-perl --with-python
Thanks in advance
Nahum Castro González
León, Guanajuato, México
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100907/9532416c/attachment.html
