[gdal-dev] Adding transaction support to the CPL ODBC layer
Even Rouault even.rouault at mines-paris.org
Thu Sep 9 16:18:23 EDT 2010
Hi Tamas,
Looks good to me. Probably not worth a RFC (IMHO) as I'd consider
cpl_odbc.h/cpp to be more or less internal GDAL API.
I assume that the changes are backward compatible so that the PGeo / ODBC
drivers still work ?
Best regards,
Even
Le jeudi 09 septembre 2010 21:21:45, Tamas Szekeres a écrit :
> Folks,
> I've created an OGR driver to provide read/write support for accessing the
> MS SQL 2008+ spatial databases. I would be in favour of including this
> driver in SVN trunk soon.
> This driver use the current CPL ODBC implementation to access the server,
> however it should somewhat be extended to support transactions at ODBC
> level.
> For this reason I've created a ticket
> http://trac.osgeo.org/gdal/ticket/3745and added the patch related to
> this common code.
> Any objections to apply these additions? I'm not sure it this change is
> large enough to write up an RFC on this, but I would do so if required.
> Best regards,
> Tamas
