[gdal-dev] Adding transaction support to the CPL ODBC layer
Fri Sep 10 02:21:17 EDT 2010
On Thu, Sep 9, 2010 at 3:21 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Folks,
> I've created an OGR driver to provide read/write support for accessing the
> MS SQL 2008+ spatial databases. I would be in favour of including this
> driver in SVN trunk soon.
> This driver use the current CPL ODBC implementation to access the server,
> however it should somewhat be extended to support transactions at ODBC
> level.
> For this reason I've created a ticket http://trac.osgeo.org/gdal/ticket/3745
> and added the patch related to this common code.
> Any objections to apply these additions? I'm not sure it this change is
> large enough to write up an RFC on this, but I would do so if required.
Tamas,
The patch looks straight forward and harmless.  Since the ODBC
API is essentially internal and the changes seem to have no effect
on existing use I think there is no need for an RFC.
I was just speaking to folks at the conference yesterday about
the need for an MS SQL Server driver in OGR so the timing of
your implementation is excellent!  I look forward to this driver
going into OGR.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Programmer for Rent
