[gdal-dev] Re: Copy only georeference between two images
canduc17 candini at meeo.it
Mon Sep 13 10:55:43 EDT 2010
My case is the first one: with gdalinfo on one of my images I obtain:
Driver: GTiff/GeoTIFF
Files: AVN_CLS57_ALAV2A127252720_20080614_20100906.tif
Size is 8505, 8378
Coordinate System is:
PROJCS["WGS 84 / UTM zone 31N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235630016,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",3],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","32631"]]
Origin = (646644.437500000000000,4872539.500000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  646644.438, 4872539.500) (  4d49'43.67"E, 43d59'28.91"N)
Lower Left  (  646644.438, 4788759.500) (  4d48'21.90"E, 43d14'14.57"N)
Upper Right (  731694.438, 4872539.500) (  5d53'18.11"E, 43d58'10.13"N)
Lower Right (  731694.438, 4788759.500) (  5d51'9.09"E, 43d12'57.82"N)
Center      (  689169.438, 4830649.500) (  5d20'38.21"E, 43d36'17.27"N)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Copy-only-georeference-between-two-images-tp5526582p5526623.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
