Re: [gdal-dev] Re: Copy only georeference between two images
Ivan Lucena ivan.lucena at pmldnet.com
Mon Sep 13 11:31:22 EDT 2010
- Using gdal_translate -a_srs you can make a copy of your second image with the assigned georeferece EPSG:32631.
- Using Python or other API you could Open the image in update mode and call SetProjectionRef with the WKT from the first image.
http://spatialreference.org/ref/epsg/32631/
http://gdal.org/gdal_translate.html
http://gdal.org/classGDALDataset.html#e2d2e231f6d632f8c2b2cf0078a01150
>  -------Original Message-------
>  From: canduc17 <candini at meeo.it>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Re: Copy only georeference between two images
>  Sent: Sep 13 '10 10:22
>  It is the same, but the georef information is a little bit shifted.
>  So I have to copy the first georef into the second image.
>  View this message in context: http://osgeo-org.1803224.n2.nabble.com/Copy-only-georeference-between-two-images-tp5526582p5526728.html
>  Sent from the GDAL - Dev mailing list archive at Nabble.com.
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
