[gdal-dev] Writing pixel values
Akhil Jaggarwal axj4159 at cs.rit.edu
Wed Sep 15 13:58:03 EDT 2010
Ivan,
I call CreateCopy() to create a copy of the input, because I need the
output to hold all the metadata.
 hDestDS = GDALCreateCopy( hDriver, pszDestFileName, hDataset, FALSE,
                                    NULL, NULL, NULL );
Is this how I create a new band for writing?
hDestDS = GDALOpen( pszDestFileName, GA_Update );
Thanks.
On Wed, Sep 15, 2010 at 11:58 AM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> Akhil,
> How did you create or opened the output? Did you also create the bands before calling GDALRasterIO?
> See examples on: http://gdal.org/gdal_tutorial.html
> Regards,
> Ivan
>>  -------Original Message-------
>>  From: Akhil Jaggarwal <axj4159 at cs.rit.edu>
>>  To: gdal-dev at lists.osgeo.org
>>  Subject: [gdal-dev] Writing pixel values
>>  Sent: Sep 15 '10 10:52
>>  Hi,
>>  Any comments/suggestions on this issue would be immensely helpful!
>>  I'm storing the pixel values in a buffer like this:
>>  pafScanline = (short int*)CPLMalloc(sizeof(short int)*nxSize*nySize);
>>  I can read the data alright. The call to GDALRasterIO is being made
>>  correctly, which I do with:
>>  GDALRasterIO(hBand, GF_Read, 0, 0, nxSize, nySize,
>>                         pafScanline,
>>                         nxSize,nySize,
>>                         GDT_Int16,
>>                         0, 0);
>>  However, when it comes to the part of writing a pixel data to an
>>  output file, the call to GDALRasterIO fails:
>>  for(i = 0; i < nySize; i++) {
>>                 for(j = 0; j < nxSize; j++) {
>>                         if( CE_Failure == GDALRasterIO( hDestDS,
>>  GF_Write, 0, 0, j, i,
>>                           change1, j, i , GDT_Int16, 0,0) ) {
>>                                   printf("Write Error!");
>>                                   return 1;
>>  Where change1 is a variable to hold pixel data that I want to change.
>>  It's declared in the following manner:
>>  short int*change1;
>>  change1 = malloc(sizeof(short int));
>>  *change1 = 1;
>>  I can't get what exactly am I missing. The file i'm using is a tiled,
>>  16 bit signed TIFF.
>>  How do I change the value at a pixel location?
>>  Thanks!
>>  _______________________________________________
>>  gdal-dev mailing list
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
