[gdal-dev] compile error
Murat Beyhan beyhan at deprem.gov.tr
Wed Sep 15 09:04:24 EDT 2010
I tried to install gdal 1.7.2 on mandriva in order to read data from
mysql.
So I faced following error
Please help me How can I solve this problem
many thanks
Murat
g++ -I../../port -I../../gcore -I../../alg -I../../ogr `php-config
--includes` -fpic -c
gdal_wrap.cpp
gdal_wrap.cpp:562: warning: deprecated conversion from string constant
to
‘char*’
gdal_wrap.cpp:867: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:867: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:867: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:867: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:867: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:868: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:868: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:868: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:868: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:868: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:869: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:869: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:870: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:870: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:870: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:870: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:870: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:882: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:882: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:882: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:882: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:882: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:883: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:883: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:883: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:883: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:883: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:884: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:884: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:885: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:885: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:885: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:885: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:885: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:915: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:915: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:915: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:915: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:915: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:916: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:916: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:916: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:916: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:916: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:917: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:917: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:918: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:918: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:918: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:918: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:918: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:1143: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1143: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1143: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:1143: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:1143: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:1144: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1144: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1144: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:1144: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:1144: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:1145: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1145: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1146: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1146: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1146: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:1146: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:1146: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:1261: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1261: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1261: error: expected primary-expression before ‘*’
token
gdal_wrap.cpp:1261: error: ‘value’ was not declared in this
scope
gdal_wrap.cpp:1261: error: initializer expression list treated as
compound
expression
gdal_wrap.cpp:1262: error: ‘zend_property_reference’ was not declared in
this
scope
gdal_wrap.cpp:1262: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1262: error: expected primary-expression before ‘*’ token
gdal_wrap.cpp:1262: error: ‘value’ was not declared in this scope
gdal_wrap.cpp:1262: error: initializer expression list treated as
compound expression
gdal_wrap.cpp:1263: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1263: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1264: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1264: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1264: error: expected primary-expression before ‘*’ token
gdal_wrap.cpp:1264: error: ‘value’ was not declared in this scope
gdal_wrap.cpp:1264: error: initializer expression list treated as
compound expression
gdal_wrap.cpp:1276: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1276: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1276: error: expected primary-expression before ‘*’ token
gdal_wrap.cpp:1276: error: ‘value’ was not declared in this scope
gdal_wrap.cpp:1276: error: initializer expression list treated as
compound expression
gdal_wrap.cpp:1277: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1277: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1277: error: expected primary-expression before ‘*’ token
gdal_wrap.cpp:1277: error: ‘value’ was not declared in this scope
gdal_wrap.cpp:1277: error: initializer expression list treated as
compound expression
gdal_wrap.cpp:1278: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1278: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1279: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:1279: error: ‘property_reference’ was not declared in this
scope
gdal_wrap.cpp:1279: error: expected primary-expression before ‘*’ token
gdal_wrap.cpp:1279: error: ‘value’ was not declared in this scope
gdal_wrap.cpp:1279: error: initializer expression list treated as
compound expression
gdal_wrap.cpp:1536: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: In function ‘void _wrap_PushErrorHandler__SWIG_1(int,
zval*, zval**, zval*, int)’:
gdal_wrap.cpp:1806: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetDescription(int,
gdal_wrap.cpp:2128: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_SetDescription(int,
gdal_wrap.cpp:2160: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_Dict(int,
gdal_wrap.cpp:2197: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_List(int,
gdal_wrap.cpp:2252: warning: deprecated conversion from string constant
to ‘char*’
_wrap_MajorObject_SetMetadata__SWIG_0(int, zval*, zval**, zval*, int)’:
gdal_wrap.cpp:2306: warning: deprecated conversion from string constant
to ‘char*’
_wrap_MajorObject_SetMetadata__SWIG_1(int, zval*, zval**, zval*, int)’:
gdal_wrap.cpp:2372: warning: deprecated conversion from string constant
to ‘char*’
gdal_wrap.cpp: At global scope:
gdal_wrap.cpp:2463: error: redefinition of ‘pval
_wrap_propget_MajorObject’
gdal_wrap.cpp:869: error: ‘pval _wrap_propget_MajorObject’ previously
declared here
gdal_wrap.cpp:2463: error: ‘zend_property_reference’ was not declared in
this scope
gdal_wrap.cpp:2463: error: ‘property_reference’ was not declared in this
scope
make[2]: *** [gdal_wrap.o] Error 1
make[2]: Leaving directory `/usr/local/gdal-1.7.2/swig/php'
make[1]: *** [build] Error 2
make[1]: Leaving directory `/usr/local/gdal-1.7.2/swig'
make: *** [swig-modules] Error 2
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
