[gdal-dev] gdal_grid from contour
Fri Sep 17 08:33:25 EDT 2010
ahmet temiz wrote:
> hello
> Does gdal_grid have a capability of generating dem from elevation
> contour lines ?
Ahmet,
The normal way of generating a DEM from contour lines with GDAL is to
burn the contours into a blank (all nodata) file with gdal_rasterize and
then to fill in the areas between contours by interpolation with
gdal_fillnodata.py.
Best regards,
