[gdal-dev] gdal_grid from contour
ahmet temiz ahmettemiz88 at gmail.com
Fri Sep 17 09:02:46 EDT 2010
thank you
I am sorry but I am not clear.
how shall we integrate elevation data if we burn vectors to all nodata ?
regards
2010/9/17 Frank Warmerdam <warmerdam at pobox.com>
> ahmet temiz wrote:
>> hello
>> Does gdal_grid have a capability of generating dem from elevation contour
>> lines ?
> Ahmet,
> The normal way of generating a DEM from contour lines with GDAL is to
> burn the contours into a blank (all nodata) file with gdal_rasterize and
> then to fill in the areas between contours by interpolation with
> gdal_fillnodata.py.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100917/85df04fe/attachment.html
