[gdal-dev] can't import osgeo or gdal in python
Christopher Barker Chris.Barker at noaa.gov
Mon Sep 20 13:33:39 EDT 2010
Jeff Hamann wrote:
> Chris,
> Thanks for responding to my post.
re-including the gdal list -- I suspect you didn't mean to reply only to me.
> I'm not using the pre-built frameworks as I'm trying to construct a
> stack that can be "easily" built, installed, and replicated on Linux,
> FreeBSD (my fav), windows (not so much) and OSX.
In that case, I'd forget about the framework build -- you might as well
keep it as similar to the other *nix's
If you're not trying to do frameworks, and you don't need to
re-distribute to other architectures or OS-X versions, it should be a
pretty straightforward build.
One issue to look for: there are a lot of python versions available for
the Mac: Apple's, the python.org one, fink, macports, build-your-own, ...
so make sure you know what version you are using, and that you are doing
everything with that same version.
>>>  When I try to "run" (again newbie
>>> talking here, so be patient), a python script and import gdal:
>>> /Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so
>>>  Expected in: flat namespace
This is something I know next to nothign abuot, but I know there is
something in OS-X with things being build with either "flat" or "nested"
namespaces -- perhaps those have gotten confused with your build? Did
you build your own Python?
Not much, sorry.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
