[gdal-dev] OGR MS SQL Spatial driver has been added
Tamas Szekeres szekerest at gmail.com
Mon Sep 20 16:55:54 EDT 2010
2010/9/20 David Lowther <dlowther at coordinatesolutions.com>
> It seems almost as if there is an index off in the field information.
David,
That's strange indeed. What is the database type of this field in the table?
Could you provide your test data to reproduce this?
> I am also not seeing any features when I render the layer in Mapserver
> (though that could be any number of things as I am just getting started with
> OGR MSSQL in Mapserver).
It would be helpful to see your mapfile to make sure about the problem.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100920/a018e33b/attachment.html
