Re: [gdal-dev] can't import osgeo or gdal in python
Ivan Lucena ivan.lucena at pmldnet.com
Mon Sep 20 21:43:41 EDT 2010
Well, I am following other lead.
I am trying to uninstall the python.org 2.7 and use only the 2.6 from Apple that is actually working well with GDAL.
I did some search and found that tip on python bug report issue7107 on how to uninstall python from OS X:
http://bugs.python.org/issue7107
Regards,
Ivan
>  -------Original Message-------
>  From: William Kyngesburye <woklist at kyngchaos.com>
>  To: Ivan Lucena <ivan.lucena at pmldnet.com>
>  Cc: gdal-dev <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] can't import osgeo or gdal in python
>  Sent: Sep 20 '10 19:54
>  For both of you, it now sounds like the _gdal.so might not be linking libgdal at all.
>  What does this return:
>  otool -L /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/osgeo/_gdal.so
