[gdal-dev] legend of the dem ?
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Sep 23 00:33:22 EDT 2010
ahmet,
The gdaldem color-relief utility uses the color entries from a text file
which is given as the argument color_text_file. If you did create a map
using gdaldem color-relief, you should already have the file. Use the
entries from it.
On Wed, Sep 22, 2010 at 1:12 AM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
> So, what are they ?
> 2010/9/21 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> > ahmet,
> > You have to create a legend of the dem from the color configuration file
> > using some other tool.
> > On Wed, Sep 22, 2010 at 12:32 AM, ahmet temiz <ahmettemiz88 at gmail.com>
> > wrote:
> >> I used gdaldem color-relief and  created the map.
> >> Now, how can I generate the legend of the dem ?
> >> kind regards
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > /tʃaɪθənjə/ /kʊmɑr/
> > +91-9494447584
> > 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100923/ecffcc56/attachment.html
