[gdal-dev] legend of the dem ?
ahmet temiz ahmettemiz88 at gmail.com
Thu Sep 23 08:18:18 EDT 2010
I learnt later. This color file should be created by myself.
I had asked if there was any automatic way of generation of that file
as in "GMT makecpt"
regards
2010/9/23 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> ahmet,
> The gdaldem color-relief utility uses the color entries from a text file
> which is given as the argument color_text_file. If you did create a map
> using gdaldem color-relief, you should already have the file. Use the
> entries from it.
> On Wed, Sep 22, 2010 at 1:12 AM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
>> So, what are they ?
>> 2010/9/21 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
>> > ahmet,
>> > You have to create a legend of the dem from the color configuration file
>> > using some other tool.
>> > On Wed, Sep 22, 2010 at 12:32 AM, ahmet temiz <ahmettemiz88 at gmail.com>
>> > wrote:
>> >> I used gdaldem color-relief and  created the map.
>> >> Now, how can I generate the legend of the dem ?
>> >> kind regards
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> >> gdal-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> > Best regards,
>> > Chaitanya kumar CH.
>> > /tʃaɪθənjə/ /kʊmɑr/
>> > +91-9494447584
>> > 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
