[gdal-dev] Re: NITF driver reads GEOLOB, but does not write it.
turtlewax frankhevans at yahoo.com
Thu Sep 23 16:32:44 EDT 2010
Even, thanks for responding.  The ultimate goal is to serve up NITFs via
MapServer. So if we need to specify a TRE option, we would need to define it
in the mapfile.
Still, this is a good lead. Do you have any guidance on exercising this from
the command-line?
gdal_translate -of NITF -co TRE=GEOLOB="CETAG = 'GEOLOB'\n        CEL   =
'00048'\n        ARV   = '073932800'\n
    BRV   = '080076800'\n        LSO   = '-096.9774560321'\n        PSO   =
'+045.1446198929'\n        IS_OVERFLOW =        0" foo.tif foo.ntf
Input file size is 1543, 1670
ERROR 1: Cannot read GEOLOB TRE. Wrong size.
0...10...20...30...40...50...60...70...80...90...100 - done.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/NITF-driver-reads-GEOLOB-but-does-not-write-it-tp5563144p5564612.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
