[gdal-dev] can not connect top postgis db using GDAL
Clay, Bruce bclay at ball.com
Thu Sep 23 17:25:34 EDT 2010
Frank:
  Thanks for the reply.  I tried again with"
strcat(connectBuf, "PG:dbname='postgis' host='<hostname>' port='5432'
user='postgres' password='>Pwd>'");
*dataSource = OGRSFDriverRegistrar::Open(connectBuf
/*connectString.c_str() */, FALSE);
And still no connection and *dataSource was returned NULL.
I put a breakpoint in GdalErrorHandler and the code did not go there so
apparently no error was signaled during the connection attempt
I also tried:
L:\SupportLibraries\gdal-1.7.1\bin\release>ogrinfo -ro
PG:"host=<hostname> user=postgres password=<pwd>"
FAILURE:
Unable to open datasource `PG:host=<hostname> user=postgres
password=<pwd>'
 with the following drivers.
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> REC
  -> Memory
  -> BNA
  -> CSV
  -> GML
  -> GPX
  -> KML
  -> GeoJSON
  -> GMT
  -> ODBC
  -> PGeo
  -> PostgreSQL
  -> PCIDSK
  -> XPlane
  -> AVCBin
  -> AVCE00
  -> DXF
  -> Geoconcept
  -> GeoRSS
  -> GPSTrackMaker
  -> VFK
From the list we can see PostgrSQL but no reason was given for the
failure
Any other suggestions would be greatly appreciated.
Bruce
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thursday, September 23, 2010 5:05 PM
To: Clay, Bruce
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] can not connect top postgis db using GDAL
Clay, Bruce wrote:
> I can not connect to a posgresql/postgis database using GDAL.  I have
> verified that the PostgreSql drivers are in the DLL by calling ogrinfo
> -formats.
> PostgreSql is on the list
> From c++ code I try the following:
> strcat(connectBuf, "PG:\"dbname='postgis' host='<ip address'
port='5432'
> user='postgres' password='<pwd>'\"");
Bruce,
You should not be including the extra escaped double quotes in the
connection
string.  You likely saw an example in this form intended for use at the
commandline where the quotes would be interpreted by the shell, and keep
the
whole connection string together as one argument.  Try:
strcat(connectBuf, "PG:dbname='postgis' host='<ip address' port='5432'
user='postgres' password='<pwd>'");
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
