[gdal-dev] Enabling GEOS with GDAL on Windows
Alex Hagen-Zanker ahh34 at cam.ac.uk
Fri Sep 24 04:15:27 EDT 2010
  >>would love to be able to access geos without any work arounds
Jay, I am not an expert and struggled to get it working as well. I took
the following steps using nmake. If you don't have nmake, you can find
instructions for getting it by Googling. It is also an option to get
Visual Studio Express.
1. Download and compile latest version of GEOS (following their install
instructions).
2. Make sure that the GEOS Environment Variables are correct (GEOS_DIR
and GEOS_HEADERS, I suppose GEOS_DIR would be sufficient)
3. Modify GDAL's "nmake.opt" file  where it concerns GEOS, i.e. the
following lines:
# Uncomment for GEOS support
#GEOS_DIR=C:/warmerda/geos
GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
GEOS_LIB     = $(GEOS_DIR)/source/geos_c_i.lib
4. Build GDAL using nmake:
nmake /f makefile.vc clean
nmake /f makefile.vc install
nmake /f makefile.vc devinstall
5. Make sure that your GDAL uses the right geos.dll, e.g. by searching
your computer for geos.dll and renaming all unused instances.
Good luck, Alex
