[gdal-dev] ogr problems with MapInfo
Sebastian E. Ovide sebastian.ovide at gmail.com
Wed Sep 29 04:26:05 EDT 2010
Is there anyway to get more verbose outputs ?
gis at mapserver:~/data/us$ ls -la .
-rwxr-xr-x 1 gis root   3512226 2010-09-28 17:10 CA_Wild Fire Bundle.DAT
-rwxr-xr-x 1 gis root    413184 2010-09-28 17:10 CA_Wild Fire Bundle.ID
-rwxr-xr-x 1 gis root   6606336 2010-09-28 17:10 CA_Wild Fire Bundle.IND
-rwxr-xr-x 1 gis root 117387776 2010-09-28 17:11 CA_Wild Fire Bundle.MAP
-rwxr-xr-x 1 gis root       478 2010-09-28 17:10 CA_Wild Fire Bundle.TAB
gis at mapserver:~/data/us$ ogrinfo CA_Wild\ Fire\ Bundle.TAB
FAILURE:
Unable to open datasource `CA_Wild Fire Bundle.TAB' with the following
drivers.
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> REC
  -> Memory
  -> BNA
  -> CSV
  -> GML
  -> GPX
  -> KML
  -> GeoJSON
  -> GMT
  -> OCI
  -> PCIDSK
  -> XPlane
  -> AVCBin
  -> AVCE00
  -> DXF
  -> Geoconcept
  -> GeoRSS
  -> GPSTrackMaker
  -> VFK
from another machine on the same data:
sebas at SeansPC:~$ ogrinfo MapInfo/CA_Wild\ Fire\ Bundle.TAB
Had to open data source read-only.
INFO: Open of `MapInfo/CA_Wild Fire Bundle.TAB'
      using driver `MapInfo File' successful.
1: CA_Wild Fire Bundle
sebas at SeansPC:~$
On Tue, Sep 28, 2010 at 6:18 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Sebastian,
> Can you provide a long list of the directory?
> On Tue, Sep 28, 2010 at 10:09 PM, Sebastian E. Ovide <
> sebastian.ovide at gmail.com> wrote:
>> Hi All,
>> I have built gdal with MapInfo support:
>> gis at mapserver:~/data/us$ ogrinfo --formats
>> Supported Formats:
>>   -> "ESRI Shapefile" (read/write)
>>   -> "MapInfo File" (read/write)
>> And I have MapInfo files. Now running ogrinfo:
>> gis at mapserver:~/data/us$ ogrinfo -ro .
>> OGR: OGROpen(.) failed.
>> FAILURE:
>> Unable to open datasource `.' with the following drivers.
>>   -> ESRI Shapefile
>>   -> MapInfo File
>> I am using the same data on another machine and it is working well.... so
>> the data is not corrupted...
>> any ideas ?
>> Sebastian E. Ovide
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100929/46807d4b/attachment.html
