[gdal-dev] ogr problems with MapInfo
Sebastian E. Ovide sebastian.ovide at gmail.com
Wed Sep 29 04:40:20 EDT 2010
ok guys, something weird is happening...
I have the data in a windows share folder on another machine. So I have
mounted that folder on a VBox Ubuntu. ogrinfo would not work on those files.
I copied those files to another directory:
us is the smb folder
tmp is a local folder
cp us/* tmp/
on tmp ogrinfo works like a charm !!!
any ideas ?
On Tue, Sep 28, 2010 at 6:18 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Sebastian,
> Can you provide a long list of the directory?
> On Tue, Sep 28, 2010 at 10:09 PM, Sebastian E. Ovide <
> sebastian.ovide at gmail.com> wrote:
>> Hi All,
>> I have built gdal with MapInfo support:
>> gis at mapserver:~/data/us$ ogrinfo --formats
>> Supported Formats:
>>   -> "ESRI Shapefile" (read/write)
>>   -> "MapInfo File" (read/write)
>> And I have MapInfo files. Now running ogrinfo:
>> gis at mapserver:~/data/us$ ogrinfo -ro .
>> OGR: OGROpen(.) failed.
>> FAILURE:
>> Unable to open datasource `.' with the following drivers.
>>   -> ESRI Shapefile
>>   -> MapInfo File
>> I am using the same data on another machine and it is working well.... so
>> the data is not corrupted...
>> any ideas ?
>> Sebastian E. Ovide
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100929/505aaf89/attachment.html
