[gdal-dev] JVM crash on making a call to the class/method OGRLineString::exportToWkt
Brian Kelly briansmailbox at gmail.com
Thu Sep 30 09:18:48 EDT 2010
Hi all,
Apologies in advance for not providing a testable case that can be fired up.
I'm hoping the background info provided and investigation work shown below
is enough to help trace what the issue is.
PROBLEM DEFINITION:
I work with a custom java application that loads GIS data using GDAL
(current TRUNK code in use though issue occurs with v1.7.2 also). We can
load a variety of data types (MapInfo, DGN,etc) with no issues. A problem
occurs when TIGER data is loaded though - the TIGER data loads and is
viewable but after a few pans and zooms the JAVA server process crashes.
This seems to happen when it tries to unload loaded features. Was using US
Census data tiger files.
PROBLEM ANALYSIS:
Two sources of debug information were looked at. A (1) general log file
generated by java and (2) a core dump file. The outputs of these are below.
1. LOG NUMBER ONE: The log file generated on crash indicates the source of
the problem is the GDAL library when features are deleted.
Current thread (0x0000000041a4d800):  JavaThread
"FeatureNativeObjectsCleaner" daemon [_thread_in_native, id=28311,
stack(0x00007ff5f4cc8000,0x00007ff5f4dc9000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR),
si_addr=0x000000000000003a
Stack: [0x00007ff5f4cc8000,0x00007ff5f4dc9000],  sp=0x00007ff5f4dc77a8,
free space=3fd0000000000000018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
C  0x0000000042355af0
j  org.gdal.ogr.FeatureNative.delete()V+23
2. LOG NUMBER TWO: A linux core dump was captured when the JVM crashed. This
was analysed for more precise details using the GDB debugger using the
approach outlined at
http://www.dialogic.com/support/helpweb/dxall/tn957.aspx
The output from the core dump file analysis was:
Loaded symbols for /usr/lib/jvm/jrrt-4.0.1-1.6.0/jre/lib/amd64/libdcpr.so
Core was generated by `/usr/lib/jvm/java-6-jrockit/bin/java -Xms2048m
-Xmx2048m -Djava.util.logging.ma'.
Program terminated with signal 6, Aborted.
#0  0x00007f51ac719a75 in raise () from /lib/libc.so.6
(gdb) bt
#1  0x00007f51ac71d5c0 in abort () from /lib/libc.so.6
#2  0x00007f51ac7534fb in ?? () from /lib/libc.so.6
#3  0x00007f51ac75d5b6 in ?? () from /lib/libc.so.6
#4  0x00007f51ac7616d8 in ?? () from /lib/libc.so.6
#5  0x00007f51ac76258e in malloc () from /lib/libc.so.6
#6  0x00007f515d06c262 in OGRLineString::exportToWkt (this=0x7f5154722bb0,
    ppszDstText=0x7f5158804728) at ogrlinestring.cpp:1049
#7  0x00007f515d51655f in OGRGeometryShadow_ExportToWkt__SWIG_1
(jenv=0x5952bf0,
    jcls=<value optimized out>, jarg1=6, jarg1_=0xffffffffffffffff)
    at ogr_wrap.cpp:1792
#8  Java_org_gdal_ogr_ogrJNI_Geometry_1ExportToWkt_1_1SWIG_11
(jenv=0x5952bf0,
    at ogr_wrap.cpp:7166
#9  0x00007f5166de2715 in ?? ()
#10 0x00000000827520c0 in ?? ()
1. The core dump file indicates that an exception occurs in the file
ogrlinestring.cpp at L1049. In the GDAL trunk source code that I have this
corresponds to the line:
       *ppszDstText = (char *) VSIMalloc( nMaxString );
2. The output from Log #1 indicates that there might be an issue with memory
pointers. This is based on the SEGV_MAPERR error output and the opinion on
the post here:
http://www.linuxquestions.org/questions/programming-9/free-invalid-next-size-fast-c-error-729852/
It looks like the problem could be a memory pointer size issue related to
ogrlinestring. If anyone could take a quick look and suggest a fix that
would be appreciated. I'm a java programmer lost in a C++ world on this one.
Thanks,
Brian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100930/10ffc668/attachment.html
