[gdal-dev] compilation problem
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Apr 4 03:53:16 EDT 2011
Ahmet,
These kind of compilation errors usually resolve themselves if you perform a
"make clean" or start with a fresh copy. Probably caused by 'make' not
seeing a modification of file or due to an interrupted compilation. Also, I
noticed some problems when running make with the --jobs option.
2011/4/4 ahmet temiz <ahmettemiz88 at gmail.com>
> hello
> hello I encountered this problem when I compiled
>  "gdal-svn-trunk-2011.03.27"
> sr/local/gdal/frmts/envisat/EnvisatFile.c:1046: undefined reference to
> `__stack_chk_fail_local'
> /usr/local/gdal/frmts/o/EnvisatFile.o:/usr/local/gdal/frmts/envisat/EnvisatFile.c:419:
> more undefined references to `__stack_chk_fail_local' follow
> what can I do ?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> Bilgi ve CBS grubu
> Eskişehir Yolu 10. km.
> Lodumlu / Ankara
> Tel : 0 312 2872680 / 1535
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110404/5837ec10/attachment.html
