[gdal-dev] ogr2ogr: problems converting from shapefile to kml
Even Rouault even.rouault at mines-paris.org
Wed Apr 6 19:02:25 EDT 2011
Le jeudi 07 avril 2011 00:39:59, Vishal Mehta a écrit :
> Hi all,
> I'm having some trouble with a simple conversion from shapefile to kml.
> Description
> 1. I need to have a points file in kml that is is EPSG 3857 (the mercator
> that Google uses)
I'm afraid that you are loosing your time. KML coordinates must be expressed
in EPSG:4326 per the spec.
See http://code.google.com/intl/fr/apis/kml/documentation/kmlreference.html
and specifically :
"""<Location>
    Specifies the exact coordinates of the Model's origin in latitude,
longitude, and altitude. Latitude and longitude measurements are standard lat-
lon projection with WGS84 datum. """
This is also reminded in the OGR KML doc : see
http://gdal.org/ogr/drv_kml.html
