[gdal-dev] Can't read transformation coefficients from tiff
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Apr 7 04:34:49 EDT 2011
Chris,
What did you use to view the image? Were you able to read any other Geo
related data with that?
On Thu, Apr 7, 2011 at 1:56 PM, Goo Creations <goocreations at gmail.com>wrote:
> Hi all
> I tried to read the transformation coefficients by using
> GDALDataset::GetGeoTransform. This function however returned CE_Failure, so
> i assume that the values are not stored in the metadat.
> When I view the image, the image is rotated. There is no world file or
> anything that could cause the rotation.
> So my question: If these values are not stored in the metadata, how does
> GDAL handle the rotation, pixel size, etc?
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110407/0c3e39b9/attachment.html
