[gdal-dev] Re: Catch a GDALOpen exception
Mateusz Loskot mateusz at loskot.net
Thu Apr 7 12:53:59 EDT 2011
On 07/04/11 08:04, canduc17 wrote:
> Ok. So if I have well understood the most safe thing to do is the following:
> myDataset = (GDALDataset *) GDALOpen( "myFile.tif", GA_ReadOnly );
> 	if(myDataset == NULL )
> 		return 14;
Depends on what you consider as "most safe".
In terms of exception safety and safe management of resources in C++,
safe version of your code is:
// Using either C++0x or Boost shared_ptr implementation
typedef std::shared_ptr<GDALDataset> dataset_t;
dataset_t make_dataset(GDALDataset* pds)
     dataset_t ds(pds, ::GDALClose);
     return ds;
dataset_t open_dataset(char const* const file)
     dataset_t ds(make_dataset(
         static_cast<GDALDataset*>(
             ::GDALOpen(file, ::GA_ReadOnly))));
     if(!ds)
         // or return ds and let user to test against nullptr
         throw std::runtime_error("failed to open dataset");
     return ds;
dataset_t myDataset(open_dataset("myFile.tif"));
// if open_dataset throws, no need to test against nullptr
Best regards
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
