[gdal-dev] regular expression in ogr2ogr
Even Rouault even.rouault at mines-paris.org
Fri Apr 8 08:06:46 EDT 2011
Selon ahmet temiz <ahmettemiz88 at gmail.com>:
The SQL engine of OGR has not support for general-purpose regular expressions,
but it sounds what you need is the LIKE operator. You can find the documentation
here : http://gdal.org/ogr/ogr_sql.html.
> hello
> how can I use regular expression in ogr2ogr -sql "   "
> something like :
> ogr2ogr -sql "select il,ilce,koy,etkili_nak from kd_nakil where il
> ???~ ???  'kastamonu'"  kasta2_kd_nakil.shp  kd_nakil.shp
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Baþkanlýðý
> Planlama ve Zarar Azaltma Dairesi Baþkanlýðý
> Bilgi ve CBS grubu
> Eskiþehir Yolu 10. km.
> Lodumlu / Ankara
> Tel : 0 312 2872680 / 1535
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
