[gdal-dev] Wrong parameter value for EPSG:3168 and EPSG:3375 (RSO)
Even Rouault even.rouault at mines-paris.org
Sat Apr 9 04:50:42 EDT 2011
Selon Hilmy Hashim <hilmyh at gmail.com>:
I can confirm the bug. It is in fact a bug in libgeotiff. I have reported it as
http://trac.osgeo.org/geotiff/ticket/38 with an attached patch to fix it.
> Hi list,
> I assigned geotiff raster an srs using gdal_translate with the EPSG number
> as follows:
>   gdal_translate -a_srs EPSG:3168 sourcefile destinationfile
> Using gdalinfo, I notice that the false_easting parameter is 0 where it
> should be 804670.24
> Coordinate System is:
> PROJCS["Kertau (RSO) / RSO Malaya (m)",
>     GEOGCS["Kertau (RSO)",
>         DATUM["Kertau_RSO",
>             SPHEROID["Everest 1830 (RSO
> 1969)",6377295.664,300.8017000000015,
>                 AUTHORITY["EPSG","7056"]],
>             AUTHORITY["EPSG","6751"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4751"]],
>     PROJECTION["Hotine_Oblique_Mercator"],
>     PARAMETER["latitude_of_center",4],
>     PARAMETER["longitude_of_center",102.25],
>     PARAMETER["azimuth",323.0257905],
>     PARAMETER["rectified_grid_angle",323.1301023611111],
>     PARAMETER["scale_factor",0.99984],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","3168"]]
> I am using OSGeo4W on Windows 7 64 bit (Gdal 1.4.5.0) shell. It is the same
> with gdal 1.6, 1.7, gdal-dev, gdal 1.7.2 on Ubuntu 10.04 and QGis 1.7 (gdal
> 1.8).
> I checked the OSGeo4W\share\proj\epsg file, but the values there are
> correct. The anomaly also affects EPSG:3375 which uses the same projection.
> QGis or Geoserver doesn't have a problem displaying the raster with the
> assigned srs, so it looks like its just a problem with gdalinfo.
> regards
> *Hilmy*
