[gdal-dev] gdal_translation interpolation
kui yang yang3kui at gmail.com
Mon Apr 11 02:40:36 EDT 2011
hi,
What's  the interpolation method used in gdal_translate
when the size of the input dataset is changed with the
-outsize flag?
Are there different interpolation methods that can be used?
If yes, what are they and the flags to use?
Thanks in advance.
yang
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110411/362b5151/attachment.html
