[gdal-dev] Problems building GDAL 1.8.0 from sources
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Apr 11 15:17:42 EDT 2011
Alexander,
Changing the configuration can sometimes mess up the build process. Try your
latest configure command on a fresh source and build again.
On Tue, Apr 12, 2011 at 12:31 AM, Alexander Bruy
<alexander.bruy at gmail.com>wrote:
> Hi all,
> I try to build GDAL 1.8.0 under Salckware 13.1 with GRASS support.
> As first step I build GDAL without GRASS support with this options
> ./configure --prefix=/usr \
>  --exec-prefix=$PKG/usr \
>  --with-pymoddir=/usr/lib/python/site-packages \
>  --with-libtiff=/usr/lib \
>  --with-geotiff=/usr/lib \
>  --with-geos=yes \
>  --with-jasper=yes \
>  --with-sqlite3=/usr \
>  --with-poppler=yes \
>  --with-static-proj4 \
>  --with-python \
>  --program-prefix= \
>  --program-suffix= \
>  --build=$CHOST-slackware-linux
> With this options GDAL uses system (external) libs and libtiff without
> BigTIFF
> LIBTIFF support:           external (BigTIFF=no)
> But ./configure script can't find SQLite
> checking for sqlite3_open in -lsqlite3... no
> checking for SQLite3 library >= 3.0.0... disabled
> SQLite 3.6.23.1 installed and all libs and includes available.
> I think this is because libdl - the dynamic linker library don't
> automatically supported on Slackware. This is first issue.
> Ok, I build GDAL without SQLite, then I build and install
> GRASS 6.4.1RC1. Now when I try to configure GDAL
> with GRASS as
>  --with-geos=yes \
>  --with-jasper=yes \
>  --with-grass=/usr/grass-6.4.1RC1 \
>  --with-python \
>  --program-prefix= \
>  --program-suffix= \
> I get strange output about libtiff support
> LIBTIFF support:           external (BigTIFF=yes)
> Strange, previous build have BigTIFF=no...
> Also building with this config failed with errors
> geotiff.cpp: In member function ‘virtual CPLErr
> GTiffRasterBand::SetColorTable(GDALColorTable*)’:
> geotiff.cpp:1383: error: ‘TIFFUnsetField’ was not declared in this scope
> geotiff.cpp: In member function ‘void GTiffDataset::WriteGeoTIFFInfo()’:
> geotiff.cpp:4183: error: ‘TIFFUnsetField’ was not declared in this scope
> geotiff.cpp: In static member function ‘static int
> GTiffDataset::WriteMetadata(GDALDataset*, TIFF*, int, const char*,
> const char*, char**, int)’:
> geotiff.cpp:4635: error: ‘TIFFUnsetField’ was not declared in this scope
> make[2]: *** [../o/geotiff.lo] Error 1
> make[2]: Leaving directory `/tmp/txz/gdal-1.8.0/frmts/gtiff'
> make[1]: *** [gtiff-install-obj] Error 2
> make[1]: Leaving directory `/tmp/txz/gdal-1.8.0/frmts'
> make: *** [frmts-target] Error 2
> Any thoughts why this happens and how can be fixed?
> Thanks
> Alexander Bruy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110412/ff876959/attachment.html
