[gdal-dev] gdalinfo doesn't show GEOS projection info
kingkastle kingkastle4004 at gmail.com
Tue Apr 12 10:24:35 EDT 2011
Greetings,
I'm working with hdf5 file  with the following attributes:
(obtained with hdfview)
http://osgeo-org.1803224.n2.nabble.com/file/n6265339/hdf5view.bmp
However, when I gdalinfo the file, I get the following information:
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 1701, 651
Coordinate System is:
GEOGCS["WGS 84",
   DATUM["WGS_1984",
       SPHEROID["WGS 84",6378137,298.257223563,
           AUTHORITY["EPSG","7030"]],
       TOWGS84[0,0,0,0,0,0,0],
       AUTHORITY["EPSG","6326"]],
   PRIMEM["Greenwich",0,
       AUTHORITY["EPSG","8901"]],
   UNIT["degree",0.0174532925199433,
       AUTHORITY["EPSG","9108"]],
   AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  651.0)
Upper Right ( 1701.0,    0.0)
Lower Right ( 1701.0,  651.0)
Center      (  850.5,  325.5)
Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
 Metadata:
   DSSF:CLASS=Data
   DSSF:PRODUCT=DSSF
   DSSF:PRODUCT_ID=111
   DSSF:N_COLS=1701
   DSSF:N_LINES=651
   DSSF:NB_BYTES=2
   DSSF:SCALING_FACTOR=10
   DSSF:OFFSET=0
   DSSF:MISSING_VALUE=-1
   DSSF:UNITS=W/m**2
   DSSF:CAL_SLOPE=1
   DSSF:CAL_OFFSET=0
So, basically I can't see in the gdalinfo the following information:
+) Proyection used
+) Origin
+) Pixel size
In fact, when I do gdal-translate the file created is not georeferenced
rightly.
In my opinion, the problem is that the hdf5 attributes are imcomplete or not
rightly defined,
Please let me know your opinion
Many thanks in advance and best regards,
Rafa
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdalinfo-doesn-t-show-GEOS-projection-info-tp6265339p6265339.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
