[gdal-dev] ArcSDE: connection times too long
Tue Apr 12 10:47:28 EDT 2011
On 11-04-12 10:33 AM, Duarte Carreira wrote:
> Hi listers.
> I’m seing a very long delay while connecting to ArcSDE. Even if I just do
> ogrinfo on a single layer I still have to wait a few minutes before I get
> anything back.
> Any parameter I can use?
Duarte,
The SDE driver docs at http://www.gdal.org/ogr/drv_sde.html says:
"If the layer parameter is specified then the SDE driver is able to skip
reading the summary metadata for each layer; skipping this step can be a
significant time savings."
So try listing the layer of interest in the connection string.
   SDE:server,instance,database,username,password,layer
Best regards,
