[gdal-dev] ArcSDE: connection times too long
Duarte Carreira DCarreira at edia.pt
Tue Apr 12 12:12:35 EDT 2011
Hi Frank.
I do that already:
ogrinfo -so -ro SDE:server,5151,,user,pdw user.featureclass
Notice that I separate the layer name with a blank space. Using a comma does not work for me (wonder if the docs are right on that??).
I still wait quite a bit. This is a mid-sized db, with some 1200 feature classes...
Duarte
-----Mensagem original-----
De: Frank Warmerdam [mailto:warmerdam at pobox.com]
Enviada: terça-feira, 12 de Abril de 2011 15:47
Para: gdal-dev at lists.osgeo.org
Assunto: Re: [gdal-dev] ArcSDE: connection times too long
On 11-04-12 10:33 AM, Duarte Carreira wrote:
> Hi listers.
> I'm seing a very long delay while connecting to ArcSDE. Even if I just do
> ogrinfo on a single layer I still have to wait a few minutes before I get
> anything back.
> Any parameter I can use?
Duarte,
The SDE driver docs at http://www.gdal.org/ogr/drv_sde.html says:
"If the layer parameter is specified then the SDE driver is able to skip
reading the summary metadata for each layer; skipping this step can be a
significant time savings."
So try listing the layer of interest in the connection string.
   SDE:server,instance,database,username,password,layer
Best regards,
