[gdal-dev] ArcSDE: connection times too long
Tue Apr 12 12:31:50 EDT 2011
On 11-04-12 12:12 PM, Duarte Carreira wrote:
> Hi Frank.
> I do that already: ogrinfo -so -ro SDE:server,5151,,user,pdw
> user.featureclass
> Notice that I separate the layer name with a blank space. Using a comma does
> not work for me (wonder if the docs are right on that??).
> I still wait quite a bit. This is a mid-sized db, with some 1200 feature
> classes...
Duarte,
In your case you are passing user.featureclass as the layer name to
ogrinfo telling it that you only want to report on that layer.  But
to avoid opening all layers, you should also include it in the connection
string.
eg.
ogrinfo -so -ro SDE:server,5151,,user,pdw,user.featureclass user.featureclass
Best regards,
