[gdal-dev] Re: FileGDB OGR driver test
Even Rouault even.rouault at mines-paris.org
Tue Apr 12 14:48:44 EDT 2011
Le mardi 12 avril 2011 20:40:58, Matt Wilkie a écrit :
>  > ArcGIS 10 FileGDB's right ?
> If the api allows for using gdb's from different versions then the test
> suite should have different versions too. In any case I can make v10 gdb's.
No, the FileGDB API only reads v10 gdb's.
> > Current GDAL trunk builds against FileGDB API beta3 under Linux 32bit.
> > Too bad ESRI doesn't provide any 64bit build of the FileGDB API (yet...
> We are working on a Linux 64-bit release of the File Geodatabase API. It
> will not release with the 1.0 release of the API, but as a part of a
> follow on release later this year.
> Lance Shipman
> Geodatabase Product Engineer, File Geodatabase
> esri
